I viewed Steve Saunders timing belt change video on this website. When I took off the old right side belt my cam pulley slipped out of place like his did in the video. I installed new belt on left side with no problem and all marks lined up. When I went to the right side and put new belt on, pulley was still not lined up. In the video it doesn't show how he realigned the pulley that slipped. How should I fix my problem?
It seems like for the right belt to line up the is almost half stroke. I've done it twice now, onceby myself and once with help... I recomend having help but you can do it. What i did is use a large screw driver in the pully and used the case to pry against and force the pully into possition while I slipped the belt on. Doing it my self it was a tooth off 3 times in a row, so double and tripple check it once you think you're done.
2000 GL1500SE
When I changed mine, what I did was put a wrench on the bolt on that sproket and turn it where I wanted it and put the belts back on. Not the recommended procedure but it worked. You might want to give it a snug back the right way when you get through if you do try it that way.
Looks like it the way Honda does it :)
If you are referring to the timing marks on the back cover they rarely look like both line up at the same time. Left and right that is. However if you can actually put your head on level with the marks you'll see they are off by less than one tooth. That's the correct position.
