CastleWing wrote:
Could be broken windings, bad rotor, bad regulator or rectifier or such. Sounds like you have already eliminated the brushes.
The white (output) wire from the alternator goes through the 55-amp main fuse and connects with the positive battery cable at the starter relay switch A. Could possibly be a connection issue somewhere along the way but it is more than likely the alternator.
CastleWing wrote:
I am no expert by any stretch of the imagination but if your alternator is not generating any voltage I would say it is bad.
