1 - 20 of 26 Posts
Hello Everyone.
I am totally new so if I have put this in the wrong forum- oops and all.
I have an 89 gl 1500.
My left cornering light was not working so I removed the light housing and pulled the bad bulb out. It took a month for the parts shop to get me a replacement as they ordered the wrong bulb from the start.
I get home and install the bulb today and find that for some reason the bulb remains on.
That doesnt make much sense to me. So I begin to diagnose it . I can find absolutely nothing in the repair manual on the cornering lights. When I activate the right turn signal the cornering light on that side will come on and go off on demand. but not the left.
Based on that info I think that their is a separate relay and the switch must be a dpdt or multi-throw switch of some kind and either it is staying engaged or I have a relay with a bad side.
I have the mechanics repair manual for my model. I ordered it specifically to track down gremlins like this.
The repair manual has a lot of info on everything from pulling the engine to whatever but nothing seems to be present on the cornering lights in spite of the fact that they are part of its turn signal electronics.
I really would like to isolate this bugger. and nail it down.
I have been on the web and searched to no avail. lots of adds seem to exist to sell me something but nothing to cure this problem.
please if someone has some data on wtf! is the cause I would be very appreciative. Thanks
Veronica
:X
Pwhoever
Just a guess on this one but try this. There should be a relay about halfway up each of the front frame rails above the cornering lights. (One for each cornering light) You will probably have to remove the lower cowling that holds the light to see it. If that relay went bad and got stuck on, that would cause the constant power to that light. I hope this helps
OK will have to try that.
I found something in front of the timing belt cover where the light normally goes. it seems as if it is not removable though. about an inch square plastic encased thing with a couple wires coming out of it. Could be some kind of resistor. I dunno.
I have removed the entire light assembly. So do I need to remove part of the fairing to get to the relay? or is it that thing in front of the timing belt cover?
Pwhoever
No you don't have to remove the fairing, just the panel that the cornering light is attached to. If you trace the wires up that rail, it should lead you to the relay. As you have a 89, it may not be quite in the same place, possibly both relays together on the other side, but if you follow the wires, it should lead right to the relays. Each side is controlled by a seperate one controlled by the turn signal.
Try checking the ground i've had the same problem on 2 diferent bikes both had grounding problems.
well the ground works or the light would not stay on.
what I have is a circuit that is staying on no matter what. what I need is for the circuit to function as designed.
By turning off when the turn signal cancels.
Admittedly I find these lights rather useless but I dont like having thing broken. On my machine. So I am either going to fix it or I am going to extract it as I find it to be useless for what I want. I may install some led lamps in there and put them on a switch.
I just pulled the dust covers off the front wheel- Now I can see my rotors and brakes Much better. All these molding look fine but I would like some stuff to be easy access. Gotta fix a few of the moldings cuz they have some broke connectors. No biggy gonna get some fiberglass stuff for that tommarow and make my own plastic connectors on their back side.
I almost have the kick stand light switch fixed. Gotta get some Jb weld to put a larger head on the switch pin tomorrow
when Im done its going to work correctly...
Really need to nail down this problem with my cornering light- prev owner didnt bother to fix it. And as an electronics tech and someone who builds bots it is a real slap on the hinney when you have an electric gremlin like this.
Electro_cat wrote:
Hello Everyone.
Veronica
:X
Remove the right lower fairing panel. You should see two relays near the frame down tube.
The left cornering light relay has a 4-pin blue connector with two input wires (brown/white and orange/white).
The right cornering light relay has a 4-pin white connector with two input wires (brown/white and light blue/white).
This is from a 1996 and 1999 Honda service manual (electrical troubleshooting manual). Your 1988 will probably have the same color connectors. I am positive the wire colors will be the same.
Swap those relays, see if the problem switches sides.
Discussion Starter · #9 ·
Colio thanks!for the info-I will try that tomorrow
I removed the left lower panel and the one that reveals the tank so I will remove the right when I get up in the am.
Im thinking about converting the whole works over to led full time deal since I find the current design a bit useless. cornering lights are nice but it would be more useful to have them as fog lamps or aux lamps
V
Discussion Starter · #10 ·
Well I had to have a look before I hit the hay and I didnt find a relay there. I found the battery- rear brake fluid- main fuse. found the oil filler and the dipstick but nothing that looks like a relay. Maybe the 89 has it under the trunk?
If that so Im gonna have to do my home work on removing it.
Hi Veronica,
In my experience you do have to remove both lower fairings to get to the relays which reside very close to the frame/front of the bike.
Some people have converted their cornering lights to running lights (i.e. staying on all the time) by snipping the blue and white wire and the orange and white wire. Some have then put a small switch in so that they can convert them back whenever they fancy. Maybe the previous owner started the conversion and gave up part way through. Take a good look and see if their is a break in the wire/s. If not then try swapping the relays around to see if one of them has failed.
Good Luck
Pwhoever
Think further forward. The panels you have mentioned (battery, alternator, etc.)are in the middle of the bike. I hope we are talking about the same lights. These are the lights that sit just above the ground on either side of the front of the bike. They are mounted in panels that need to be taken off to see the front frame rails going up. They are below the long square amber reflector on the side of the fairing. If you could see the timing cover on the front of the bike, you were on the right track.
Anti-Guru
I hunted a little last night for the relays on my 88 -- they are in the harness just about mid-way behind the cooling fans. Knowing what Im' lokoign for now, I can see each relay (one each side) by looking thru the fairing vents (exit) for each radiator.
I'd suspect a failed relay, or a poor connection (there's really nothgin to stabilize or protect these relays and they just seem to hang on the side of the wiring harness.
at least on this 88... Hope that helps some.
my lower cornering lights are running lights. i have two toggle switches on the plastic pouch cover on the right side. they are not turn signals and the PO had them already hooked up. i am assuming he just wired them without a relay. cyclemax.com has bulbs, lots, for around $3.00. i buy 4 at a time good luck
Discussion Starter · #16 ·
thanks guys! you have been soooooooooo helpful!
BTW my fix for the side stand indicator worked!
I pulled the pin- drilled out a washer about the same diameter as the switch housing and jb welded it to the pin where the little notch is. Then reinserted it into the switch housing.
I had thought that the washer would be too big. but the extra size compensates for the kick stand horizontal movement...(right now I have it on the center stand)
I had to straighten the pin that pushes the button with a hammer for 2 hours cuz it was bent up pretty badly. Then I lubed it up with some wd 40...Got it working smooth then I did the washer trick. Apparently someone was trying to make it work by bending it it down to make contact with the side stand, but that piece seems to have had another piece attached to the pin to make contract with the stand ya know?.... So I made my own.
Btw if you do this fix I used Jb Insta weld.
Gonna get to the relays shortly
This thing is harder to work on than my old fiero. (which I wrote many fixes on btw)
OH and Dbohrer thanks for the pm Gonna go after it this week end. Getting that side stand light fixed was a major victory so Im pretty happy about that. Might have to publish that as a standard fix for these bikes.
Im gonna research switching those relays over to solid state relays. I have some that have been around since old zenith data point computers- to give you some idea. They had 10 inch floppy drives...Relays over 30 years old still work reliable- no moving parts! thanks again for the help guys.
Discussion Starter · #17 ·
I just sent a pm to Dboher Thanks again.
I pull off those side pieces and I can not find a relay on either side. I find a black rectangular thing that looks like a relay but would not be since it is a sealed unit (relays are normally removable)- It has two red wires and two black wires.There is no way to remove it sept to cut the wires. I am sure this is something else. and I would have to eyeball the schematic to know. I can get to the plugs and the fans and all the goodies in there but no relays. are present that I can tell. Anyone got a photo?
I will say that this is pretty educational since I plan to paint this bike black soon. The paint shop out here in Dallas I plan to go to wants me to shell out $2500 if they pull the pieces off- So learning how to do it myself is good deal.
THanks
V
Pwhoever,
FYI........
The cornering light relays (4-pin blue) for the Aspencade's are on the left and right sides of the bike.
The cornering light relays for the SE's are both on the right side of the bike.
The left cornering light relay has a 4-pin blue connector.
The right cornering light relay has a 4-pin white connector.
THanks
V
Electro_cat,
I sent an email to the "admin" e-mail address in your web site, pictures of the relay locations are attached. Dave
I have a 1990, the previous owner said that he fitted the cornering lights himself. My relays hang down from the loom on either side just by the four wires, there does not appear to be a hanger for them (usually they have a rubber corset with a slot in it to hang on a strip of metal on the frame). They hang parallel to the frame on either side.
I have been trying to cure a short in this too! When I start the Wing in the morning it's most noticeable, and when riding in the dark, sometimes just turning the bars to left or right the cornering light flicker on and off. Not always just sometimes. Must be mangled in the loom somewhere. Does anyone know what the colours from the relays to the indicator switch are. Sometimes when I press the winker button the light stays off.
This just happens on the left side only. Is there a contact under the steering head perhaps?
Sorry to steal your thread. Welcome to the forum Electro_cat
1 - 20 of 26 Posts
