1 - 3 of 3 Posts
94 GL1500 Aspencade How do you get to the Lamp on The Dash to change the OD lamp
went riding yesterday and the OD light went out ,Its in 5th or ODno doubt about it.
and it was working now its not all other lamps work guages ECT.
Monkey with a Football
Remove the right fairing tray. Reach under the instrument cluster and find the wires for the OD light by feel.
Follow those until you get to the rubber plug where the wires go into the instrument cluster.
In an orbiting action while pulling toward the front of the bike, pull out the rubber plug and don't lose the lamp attached to it as it actually a push in socket.
Replace the lamp and reinsert the rubber socket assembly back into the rear of the instrument cluster.
You can change the O/D bulb without taking anything apart. I changed mine by reaching behind the panel. It's tight but it's doable.
1 - 3 of 3 Posts
