I have a problem with the radio on my GL1500. The symptoms are the same as if the back-up fuse is blown, although I have constant power at the radio block (red/yellow wire). Has anyone come across this problem before, or does anybody know of a company repairing radios in Ireland or the UK? I would also consider sending it to the USA. Thanks.
Hi :waving:Moonrider ,If you gave a more detailed account of the problem ,,the lads here will be able to help you out ,,
Is the tape player playing?
is the intercom working ?
etc etc etc ..:waving:cheers Ciaran
If you have an SE or Aspencade, there are two fuses to check, # 10 & 13. Not holding memory usually indicates a blown fuse or a break somewhere.
