'92 GL1500A
My 92 GL 1500A with 64K mi exhibits switch problems. Whenever a button or switch does not respond, I flood the item with CRC Electronic cleaner, wait ~ 1 min and blow the excess away with high pressure air. This has worked for the Emergency flashers, Right directional, Cruise control ON/OFF and Set, Ignition key slot and lately the Starter button. The Starter button did not respond to the cleaner in a manner typical of others, ie a little spray would make it better but many applications were needed to make a permanent fix. I then replaced the battery, 18 month old, which seemed to do the trick. After a few weeks I hit the button and got nothing so I hit it again and got the start. Again I applied the cleaner and ordered a few new relays from Goldwing Store. While waiting for the parts I polished the battery connections and the connections to the main fuse. Then I measured the resting volts on the battery in the Wing to see the 24 hour drop. The battery started at 12.78v and the next day it was 12.72v. I connected a trickled charger to the new battery while the voltage could be watched and saw the voltage go from 12.72 to 13.0 v in about 5 minutes. I put my "big" charger on the battery because it has a light that changes from red to green when the battery was considered "full" by the charger. I did this charging 2 times and waited a few days to measure the voltage. The voltage is now at 13.03v. I installed the new starter relay. Of course I did many things so it started with a minimal cranking and needed to run on some choke. The combination of things may just boil down to maintenance need for a Wing ~39 YO. I'm going to monitor the voltage and expect voltage drain from clock etc.
I needed to loosen all four left side saddlebag bolts and finally remove the front 2 bolts to allow access to the relay box. The inside of the box was very dusty. When I replaced the Ignition/Cruise relay I found that the removed relay might be a useful backup and the inside top of the relay box had space to store the used/backup
relay.
Automotive lighting Automotive tire Hood Motor vehicle Electrical wiring
It aint rocket science
Batteries will get a short term surface charge and 12.72V is a respectable at rest voltage after one day.
Starter button is different,it has a rocker ( kinda) and a small spring to load it,they just fail
'92 GL1500A
'92 GL1500A
Thanks because that spring fail is a new idea for me. How would I go about inspecting and fixing the spring. Most of my information warns that dismantling the switches/buttons is fraught with perils from loosing parts to difficulties with assembly.
1987 GL1200 Interstate
Opening up the switches for cleaning is pretty easy. Note that there are springs that like to run away and hide.
When I clean one, I do it on a clean bench or, if on the bike, with a cloth below to catch stuff.
Re-grease everything electrical using dielectric grease and make sure the springs are nice and taut.
'92 GL1500A
Discussion Starter · #8 ·
Thanks again, I'm going to do that right NOW.
That spring will jump out and then it’s time to look for a replacement,like Dennis idea,I lost mine but if i ever have to go in there I’ll use a bucket,when I replaced mine ,I just cut the wires and soldered it back together.
I’m not saying for sure that’s it but a suggestion,now I just remove the cluster and drop the whole thing in a container of marvel mystery oil,it has been a good tool for me.
Have you installed the shifter support on your bike,it’s the best add on that I have,
