1 - 3 of 3 Posts
the volume on my radio is so low when its turned all the way up you can barley hear it when the engine is off it did work fine i had it parked for a month or so and didnt ride it when i did the radio volume didnt work right any suggestions. thanks
2000 GL1500SE
I'm stating the obvious, but have you checked the Mute button on the left handlebar? Try working it a few times and see if that works. If not, you might pull the radio and check the connectors. Remove and reseat them.
There is the 5A fuse in the relay box behind the left saddlebag that is marked "backup " it controls the sound system volume.
1 - 3 of 3 Posts
