1 - 9 of 9 Posts
Hi
Hope someone can help.
I have an I pod adaptor fitted to the bike that I purchased from a company called Electrical connection. They are in USA.
My I Pod cable developed a split at the point where it connects to the i pod, so I need to replace the cable.
The problem is that at the other end of the cable is a round 8 pin connector which plugs into a green box (supplied by Electrical Connection company)
I have searched the internet but cannot find this type of cable.
I have sent several e mails to the company without a reply.
I have also called them by phone and there is no answer.
Can anyone tell me if there is a site that will have this cable, There are hundreds of I Pod cables on the market but I cannot find one with this type of connector on the other end.
Hi
Is this an 8 pin DIN connector???? Have you check their web site: http://www.electricalconnection.com/audio/audio.htm
Gl 1800 i pod connector
Hi
Yes Ive searched their website, which only shows the complete unit at 99 USD
I only need the i pod cable and as I said they dont seem to answer e mails or phone.
Think it would help if someone stateside contacted them? I have used many products from them over the years with no problems.
Hi
I just talked to the Tech at EC connections, yes they can get the cable you'll need to call them at 865.219.9192 and ask for Phil. Good luck, Terry
Make sure you account for the time difference between Spain and Eastern Daylight Time.
1 - 9 of 9 Posts
