Set up your carbs on the bench, take the caps off, level them, hook up a fuel source, high, the higher the better. Watch in the throats and in the plenum..you can see if fuel is leaking..up the jets = bad float settings, float seat or needles, down the throat = bad o ring to plenum, up the plenum main split = bad main gasket. Mine set up is not high but it still works but does not simulate the fuel pump pressure close enough; higher. bigger fuel source will.
