1 - 11 of 11 Posts
Hi all,
The fuel and temperature gauges stopped working on my '77 GL1000. I traced it down to the 7 volt regulator. I called the local Honda shop and they want $86.25 for it... ouch!!!
Anyone know where I can find one without paying top dollar for something that should cost about $10?
Thanks,
Marco
Ashland, Oregon
Thanks Ted... I'll try there if I can't find one here in the states.
G
I had the same problem on my 77 Wing a fewyears ago and I also priced a replacement. The voltage is 8 volts. I took an 8 volt regulator and just spliced it in the old one. It has been working for several years. Cost - less that $1.00
Mine was intermittant. My solution has been working for several years now.
I bypassed both input and ourput legs with a 10 MFD cap and used epoxy to make a rigid unit.
Good luck on yours.
B. J. Baum
Decatur, IL
B. J.,
That sounds great. Do you still have the part number for that 8-volt regulator? Does it look like a big transistor, or is it something that can be found at an auto parts store?
Marco
Hi
I am restoring a 1975 GL1000 and could not find a replacement 7V regulator for my blown one. So I took a Dremmel to it and reversed engineered it. Needless to say the value of the parts on the cicuit is less than US$1-00.
I can post the original circuit or a newly designed one that can handle reverse polarity.
Herman
South Africa
Discussion Starter · #9 ·
:)Id love to see what you came up with... I'm still at a loss here. I tried to use a 2N3055 transistor with a zener diode and resistor, but the zener kept going up in smoke! My email is: [email protected]
Marco
G
Marco - The regulator is a LM7808 - it is a TO220 package and can handle up to one amp, which is way more that is needed. I don't know if the by-pass caps is necessary, but I had them so I used them.
I had to buy mine mail order from B. G. Micro in Dallas, but any decent electronics (NOT RADIO SHACK) out let should stock them. Mail order is way less that a $1.00, but a local would be much more, but not much.
If you need anything further you can contact me via e-mail at
[email protected]
GOOD LUCK,
BJB
Discussion Starter · #11 ·
Thank you B. J.,
Sounds like a pretty simple fix... The Honda manual doesn't specify how much current is needed so I was trying to overengineer it a little too much. Oh well.
I'll let you know how it works.
Marco,
Ashland, OR
1 - 11 of 11 Posts
