76 GL1000
Wife followed me home the other night after I got stuck in rain. She told me when I got home,. I did not have a running light in the back.
I went out today to trouble shoot, and had no rear lighting at all in the housing.
I swapped the turn light, and it would make the taillight (both running and brake) flash when hooked to the turn circuit. Brake circuit hooked to turn, and nothing.
I checked the power, and it was kinda random, sometimes, 8 volts, and would jump to 12 when the brake switch was activated.
Tried a reserve lighting module from my parts bike, no change (may not be good anyway).
Put it all back together, and let bike run to charge battery.
After about 10 minutes of running while I was standing there the running light came on!
Still no brake light. If I pull the bulb or wires, the gauge indicator stops showing brake light when activated. If I hook everything up, the dash light works a it should (and used to), but no actual brake light.
pull wire, no dash light.
Getting frustrated as I planned my 1st full day out with the bike tomorrow.
JimD
76 GL1000
JimD
