I had this happen to me recently, when the engine is fully hot and when the fan kicks in the idle starts going down and it dies unless I give it some throttle or increase the idle speed at the screw.
First I thought that it might be a bad battery and the fan was pulling too much juice from the system but the battery read a 12.6V. I tested it with the engine off.
Before it get to the point where the fan starts it idles just fine. Sometimes when it's hot and I shut the engine off and try to start it again, the starter will not turn fully or it's having a hard time turning the engine but eventually it does turn.
What can be causing this?
