· Registered
I am trying to do a little trouble shooting. While my 1978 GL1000 bike isidling
Disconnect plug 1. no change in idle.
Disconnect plug 2. no change in idle.
Disconnect 1 and 2. No chnage in idle.
Disconnect 3. bike stalls.
Disconnect 4. Bike stalls.
I have new plugs, caps and wires. I did ohm tests.
1-2 Coil bad?
Any ideas???
Thanks,
Mike
Definite possibility or bad points/setting or connection to the coil.
· Registered
a little more info.
I tested for spark. All plugs seemed to be firing. I tested the voltage regulator. I tested something else for continuity and 60 volts across all 3 legs. The bike runs good while the battery is hooked up to battery tender. When I take bike for spin, it runs good for a few minutes. Then spits and sputters. i noticed battery was leaking. Now waiting for new battery. I hope I am done chasing problems. This all started after I rebuilt the carbs. Then I had a head gasket leak. I had to order another head after a bolt snapped inside original head. I also just installed electronic ignition.
1985 GL1200 A
I'd be concerned first about whether I had any fuel in/to the #1 and #2 carbs. Loosen those carb bowl drain screws and see if any gas drips out. You've got spark, so better check that you actually have fuel there.
