Hey guys! I'm happy to be registered on here. I was able to use the advice given by other members to solve the problems with GL1000. So here's the problem. I have taken a GL1000 engine and have put it in an EZ-GO golf cart everything's mounted it's just been getting it running which is the problem. I replaced a few parts and she runs good except for a few issues. She only runs at full choke you can rev it and it will die shortly later. I ran a compression check and she's reading at 120 psi on cylinders 1,2, and 4. But on cylinder 3 she reading about 90. Not really sure where to go from here. I did a carb rebuild and that helped. My buddy said the valves might need to be adjusted. I was debating on running some sea foam through it as well seeing as the bike sat for almost 3 years. If you have any ideas please let me know. Thanks y'all
