Have you ruled out the throttle cables? (I think it has two?) when you open the throttle and just let go of it does it "snap" back closed? there are other things to, but always start with the simplest. I have seen rust on the bar under the throttle tube do that. check for vacuum leaks? You will get it figured out.
jade
jade
