1 - 11 of 11 Posts
does anyone know how to wire up a buzzer to the indicators of a GL1000 1980 please
The Irish Crew
You can buy small inline buzzers cheaply. Very easy to fit, the splice inline to the left and right turn signal + wires.
My 1975 has a "beeper" OEM
Yep what he said
I do recall my 1000 had a buzzer on it.
housed in rubber skin with little metal grill on.
Senior Something
Mine is up by the triple tree, bundled up in the wiring. If you find it you can pull it out of the rubber cover and you will see a screw on the back of it. I had to adjust it a bit to get it working. The adjustment will also change the way it sounds a bit.
Gofastandfalldown wrote:
Does your GL1000 not already have a turn signal buzzer? Your post says it is a 1980 GL1000, but 1979 was the last year for the GL1000.
I do believe gl1000 where available in 1980 in England.
Wilf
1 - 11 of 11 Posts
