1 - 16 of 16 Posts
Head Gasket or possible head problem?
When I had that issue on my GL1100 it was the head gasket on the right side. The way those heads and head gaskets are set up it is easy to get oil in the water and have absolutely no effect on the compression.
I did not follow the advicefrom this forum and I used aftermarket instead of Genuine Honda head gaskets,so now two years later, I need to replace them again.
Peter
Guru
If you are referring to your older wing, there is a chance that you blew an "O" ring in your water pump as well. Easier to fix than a head gasket!
Hatch.
Junior Grue
It also could be the oil pump seal gone forcing oil through the water pump.
I don't know the history of the bike but if a previous owner had an oil leak under the water pump he may have plugged the weep hole which would if the oil pump seal where leaking force oil into the coolant.
78 gl1000. Thanks for the info. I've had it a while and never seemed to run quiet like I thought.Did find the floats were set from wrong place while waiting on parts. thought about the water pump but not the oil pump
Vintage Rider
It's not the oil pump, but it could be the water pump. There is a seal in there that is supposed to keep oil and coolant apart. Have you found any coolant in the oil?
The weep hole would have to be plugged for antifreeze and oil to mix. If it's only oil in the radiator, and not the other way around, I would suspect a headgasket torn between an oil galley and a water jacket.
Now, is the oil in the radiator, or do you just have a "scum" on the coolant in the reservoir?
Discussion Starter #10
no coolant in oil. drained oil and no mix at all that I can tell. pulled heads thinking it was gasket. No sign of water on valves
Disfunctional Nimatode
I would have investigated that water pump thoroughly before pullin' these heads brother.
Dang........don't know why it does this.........
Guru
Dancin bear, switch to "Firefox" as your internet browser. Things work better!
Hatch.
reason for oil in water from pump seal is oil pressure is greater in oil than water so would suspect water pump to oil pump seal before head gaskets because it was stated that no water in oil
Discussion Starter #16
yea, wish I had gotton on here before I started. Took for granted what I really didn't know I guess. Looks like you guys will make sure I get it right. God blesses people in many different ways.By the time my parts get here, I'll be a wrench bender. We will see. Gonna go wash my new dream while my old dream still sleepin
1 - 16 of 16 Posts
