Well my bike stopped starting so I pulled off the starter from the engine while the motor was still in the frame. Then I read in the repair manual telling me not to pull off the starter motor from the engine while in the frame. it says "the starter drive spoket and drive chain will move away from the hole in the engine rear cover and the motor cannot be reinstalled onto these two items"... So having already removed the starter and put it back and bolted it down, will it not work as the warning says. And how will I know if I am totally screwed or if the starter went back into its rightful place. I ask because I suspect that my problem was not the starter in the first place, and if I have to pull the engine to put the starter back in, i am pretty much getting rid of the bike, cause even then I still haven't solved my non start issue
argh
thanks
argh
thanks
