thank you sooo much. you gave me the idea of shutting down one headlight and seeing if my problem goes away. if that happens is there a fix for the twin headlight issue that you know of. i see wings on the road that look like a christmas tree. my bike is naked with led tail light two headlights. i am pretty sure that the reserve lighting unit acts like a relay for the headlight and does a few other things too. thanks again, glenn
10 pm ran bike with one headlight and same thing. noticed a flicker on headlight when switching low/high switch. sprayed switch and lubed and works better. temp at rear of reserve lighting unit is still 170 F and smells like melting plastic.
