Will someone who knows the inside of a GL1000 engine please tell
me what has happened here:
I recently had my GL1000 in a shop, where they pulled the engine,
and replaced the stator. Getting it back, I noticed a little bit
of growl when banking. Thought nothing of it. Then yesterday,
heavy and noisy internal growling when I was riding home from
work. I turned it off, and bivouacked for the night. In the
morning I decided to try to start it. Lots of growl at first,
then the growling died out, and it sounded normal when running.
Accidentally I shut it off. On restarting, the starter spun
freely without engaging anything. After a few seconds, it
engaged, and the engine started. I rode it home. No growl.
Today I took the starter out. The splines on the starter are
intact, not stripped. And it requires a nominal amount of force
to turn the starter by hand. So I think the starter is not the
problem. Inspecting the inside of the housing where the starter
mounts, the sprocket and chain look OK. They are not stripped.
The sprocket and chain do not rotate ccw. However, they rotate
clockwise very freely. I neglected to mark the chainbefore
rotating it. My questions:
Is the sprocket and chain supposed to rotate so freely like it
does?
Did I make a major timing error by not marking the chain before
rotating it?
Assuming the starter is OK, what is wrong, or, why is the starter
not engaging?
does?
rotating it?
not engaging?
