Is there a test I can perform to see if this ignition is ok? The part
is not on the bike. (1975 GL1000). Keep in mind I am somewhat
electrically challenged.
Banned
Which Dyna? ..."S" or "III"
The "S" ignition is easier to test off the bike as there is less "stuff" to hook up.
Hahaha, I made a funny - Dyna "S" = "Stuff" cause that's what they did to those modules; they stuffed 'em full of stuff.
I've Dyna troubleshooting guides HERE. Use the drop-down menu then pick the one you want.
HERE is the Dyna "S" T/S guide.
HERE is the Dyna "III" T/S guide.
If you've a power supply and a meter you can bench test them for operation. You'll test if the triggers (modules) are working or not.
Banned
If you did that test with no power to the module, I'd say that the open module is bad.
Those modules are normally closed. Magnets trigger a open circuit condition.
Put 12Vdc to the red wire and ground the plate for test. Swing the rotor magnet past the module (powered-up) and see what happens.
I'm guessing it is the left module; 3/4 cylinders (or the white wire) that is the open module.
