i read somewhere ( can't remember where) 80/81 - 2 & 1/2 turns, 82/83 - 3 turns on a rebuild
How's your ignition system Butch?good luck. rebuilt my 83 carbs 5 or6 times and still not right.runs great at idle after that ##...///. driving me crazy
Isn't 1 turn 360 degrees?Three turns is the magic number. That's 540 degrees. You have other problems if its as rich as you describe.
I've seen this debated many times. If you take a screw driver and insert it in the screw and turn it as far as you can it'll be close to 180 degrees. To get to 360 degrees you have to remove the screw driver, unwind your wrist and turn again.Isn't 1 turn 360 degrees?
While that rule seems to be reasonable (maybe change "turn" to "twist" ?) the more common advice being given here is a turn is 360 degrees rotation I believe...I've seen this debated many times. If you take a screw driver and insert it in the screw and turn it as far as you can it'll be close to 180 degrees. To get to 360 degrees you have to remove the screw driver, unwind your wrist and turn again.
So my rule is a Turn = 180 degrees.
I've done carb work on many different things over the years and the 180 rule when applied seems to get me close to where I need to start.
