1 - 9 of 9 Posts
Just finished the alternator conversion on my 1100. Have not started it yet. I am supposed to disconnect something??? when using a one wire alternator--- saw that in article some time ago. What is it I disconnect and where is plug ?
Have you disconnected the stator and regulator/rectifier?
Are you using directions from a post? and if so post a link
Hi Newday777! I guess that is my question. where do I disconnect the stator and regulator on my GL1100. Sorry if wasnt clear on original question. Followed install artical on Goldwing doc.com
Just remove the regulator/rectifier from the bike.
Do a copy and paste of the address here to help others later that read this using the forum search.
Junior Grue
If the origanal charging system was doing nothing then there is nothing more to do.
If the origanal charging system was still working just unplug the regulator as it can be plugged back in for backup if your new alternator fails.
1 - 9 of 9 Posts
