i just purchased a twenty one thousand mile bike, The bike has not beenstarted forsome time(years). After changing all the fluids and removing the plugs (Themotor moves if you put the bike in gear and push it) I hooked up a battery charger ( 2 amps) 1st thing I see is the radio has ahum, and the turn signals only work if the radio is on andthe air pump doesn't work. Next I went to see if the starter works, I heard clicking from the main relay. I used a test light to confirm there is just about no power going to the starter when you hit the starter button (Test light lights just a little) So I thought I would go to 10 amps on the charger,but I accidentally had the AMPs set at 75 AMPs. ( Yep one of those days in the making) well, now the radio doesn't work, the little light over the radio won't work,The voltage gauge doesn't work and there is a hum coming from the ignition coils. I tested all the fuses including the ones behind the turn signal and they are fine, The LED display still works but yetI no longer have a working voltage gauge or radio. Any idea what I'm missing? Thanks for any input. I've been in this hobby to many years to make a rookie mistake like I did today.
