Hi folks, rebuilding my carbs and noticed that one of the limiters in the top of the air slide is broke off. Small plastic piece with an o-ring that goes over the needle, If someone has an old set of carbs laying around I could use one. Not sure where else to find one. Thanks, Dana
Your profile says 1000, you list for a part for an 1100, so which is it? What year is it also as there are some slight differences between the 80-81 carbs and the 82-83 carbs.
The carb bodies will have a model number stamped into them, post the carb model number.
Honda carries those. around 20 dollars i believe. I think part number 16016-kc2-970 is the kit but you might double check that number. JB
Sorry on the profile, I ride a naked 78 1000 and just bought an 83 1100 interstate that I am putting together. It was tore down when I got it and I'm checking what I need as I go alone, noticed that the rear rotor is pretty bad also but going to start making a list so that I don't make to may posts. Didn't think that Honda would still have the limiters so I'll check Monday. Thanks
