Most of the 1100's will top out at 14.8 volts normally so an even 15 steady isn't all that high. Should be good for a few more years unless it starts going over 15.5 then I'd look at replacing a regulator/rectifier.
One thing that will help the system is to upgrade to a newer AGM battery. No more over flows of acid and the AGM batteries can take a higher voltage than the old acid type batteries.
