I know there is a lot on 1100 charging systems but I haveanotherquestion. When I first start bike I will get around 14.8 volts on battery at 3000rpm. After a short ride it will only get 13 volts max at 3000rpm. I sautered the yellow wires , also checked stator before connecting them at 3000rpm I got 60volts ac and all ohm readings were where they they should be. Could rectefier regulater be getting hot and causing this. thanks
