HELLO fellow goldwingers....
Where do I start, I replaced the clutch on my gl1100. The bike ran fine the bike has been sitting for about 2 months. When i go to take for a ride it starts up fine, put it in gear when I go to take off it doesn't move. I release the clutch and nothing. After a while it slowly started moving put wont go pass 15 MPH. PLEASE HELP!!!!! Also the bike is in !st gear and the clutch is release and the bike doesn't even turn off.:stumped:
Does it have any free play in the lever? The cable may have stuck and is holding the clutch partially released.
The clutch as free play, everything is just like it should be. After I changed the clutch is was riding fine. It sat for about 7 weeks, then I go ride it and the bike won't move.
After replacing the clutch did you readjust the screw in the rear of the clutch cover?
I am assuming it is an 80 or81 model.
Yes I did, when I changed the clutch. Now Iam going to adjust the clutch again to see what happens.
