gl1100 any one have step by step on how to cut down the seat?
i'll thank you later:action:
That's what I'm thinking of doing to mine plus remove some of the top rear of the pad and insert a gel pad into it. In fact I want to get some thinner and denser foam to replace what I cut out, then put in the gel pad.Keep in mind that narrowing the front of the seat does as much for lowering the height as does cutting down the thickness. Narrowing allows more of your leg length to go toward ground, as opposed to stretching around the seat!
HTH
JimC in NC (USA)
