1 - 11 of 11 Posts
The stator on my '82 GL1100 is shot and I am going to put in a new one. But should I also replace the R/R as an extra precaution?
I definately do not want to go through another stator replacement any time soon.
Brian
Rectifier / regulator...not regulator / rectifier. Or is it relaxation / recuperation? :)
Edit: Second thought it could be remove / repair. I hate accronyms. Someday the world will blow up because of them. :) FWIW.
I wouldn't unless it was bad. Regulator / rectifier will not hurt the stator in any case. Easy to replace if the need ever arrises.
:action:
Me neither, if it ain't broke don't fix it. Since it's easy to get at there's no advantage changing it without and indication that there's a problem with it. I would check the connectors around it. They can become heated from corrosion and melt the plastic or blue the connector pins which can cause trouble.
1985 GL1200 Limited Edition
If I was changing the stator, I'd change the regulator also. It's not that much more work and you've got new components with a back-up regulator...
But that's just me.....:D
1 - 11 of 11 Posts
