1 - 20 of 38 Posts
A couple weeks ago a similar thing happened. It wound up being the spark units. They were replaced and all seemed ok. On the way today i stopped and gassed up. About 5 miles later i start to lose power. If i get the spped up it was ok. I thought i was having a fuel issue. It got progressively worse to where i stalled at a light and could barey get enough power to get off the road. I can get it started but have to keep the revs up to keep it running.
Looking for ideas. I am going to check for spark but it is very bright here.
UPDATE and related issue: The issue seemed to be resolved when I was directed to the loose connector this morning. I took it out for a short ride at lunch time today and all seemed well.
On the way home it started to bog down again. I drove about the same distance as I had this morning. That started me thinking that yes that connector may have been somewhat loose, but I think the fact that the bike sat for about an hour gave things (coils ?) time to cool off. While I was waiting for my daughter to get me, I waited about 40 minutes. I tried it and it started and pulled with power. Again there was time to cool off.
Does this make sense?
Am I looking at replacing the coils?
If so, what are my options for coils?
have you checked the plug connection. the one that couple the wires by the battery?
Gas tank not venting? Crack open the gas cap and listen for a vacuum hiss.
Did get a hiss. Also tried riding with cap loose.
Plug connectio to the left of battery. White blue and yellow wires was loose. Is that the on you meant? I will let you know if that was it
I also popped the plugs and moved the bike into the shade. Tough to see a spark. It may be weak.
Wda. You have some beer money coming your way. Thank you so much.
i belive so. its in the same plug connection holder that holds the stator wire plug.
What do the plugs look like? Whiteish? Tanish? Blackish? Wet? Sootie? Gassy? Do they all look the same?
;)beer money ! awwwwh-- just send a donation to the forum instead. fair enough ? glad to help.
one of two things:
the 3-pin alternator connector , if it's hot, then there's your problem, or
Carbs are clogged, remove and rebuild, change fuel filter
Village Whack Job...
If your igniters were bad, you'll want to inspect your coils very carefully. What you describe sounds like a "leaky' coil to me.
Discussion Starter #12
BW: The igniters were bad and were replaced a couple weeks ago. The plug that wda referenced was in fact loose and the problem is resolved. As a precaution, I will check the coils. What is the best way to determine if they are leaky.
Armo: Carbs were rebuilt using a Randakk kit two months ago. Carbs were also synced.
As I stated above the connector seems to have been the culprit.
EDIT: for complete info, this is the connector that was loose. It was not disconnected as the picture shows, but I just had to touch it to have it slide out. The locking clip was not engaged.
Thank you all for your suggestions and quick replies.
jon
Discussion Starter #13
Update first post.
hate to say this --- but that is a strong indication of the igniters or coils going bad.
Discussion Starter #15
Well since I replaced the spark units with what were known good ones, I will check the coils tonight. Will a static test necessarily tell me which is bad especially if it is failing after warming up?
The best thing I know of for replacement coils is this;
http://www.goldwingfacts.com/forums/forum1/101648.html
There are 4 I know of in this area that have done it and all are very pleased with the results. My idea I know but even if it were not it's still a good mod.
yes and no :ROFL:if you have 81 coils the readings should be primary .4+/- .04 oms. secondary 22k +/- 5k oms. but most importantly look for cracks. you`ll have to dismount the coils to do this proper. spark plug connectors should read 5k+/- 10% . hope this helps some .
daves mod looks like a good one too.
Discussion Starter #18
There are about 25 cars at the local pull-a-part yard that use the coils Dave wrote about. I am going to get a set today, maybe two sets.
For anyone interested in the mod, there are aftermarket coils for the Neon/Stratus/ Voyager on Ebay for about $30.
I did remove the coils last night. I did not see any cracks although I was not looking for them. I am confident that it is failing coils based on the warmup/cooldown functionality.
Should I have had the same ability to ride the bike on two cylinders as when the spark unit failed a few weeks ago? Or, do the coils tend to fail as a set?
When it was warm, the bike would not generate enough power to go at all, this time.
Thanks again for all of your help.
heres the coil and wire lay out.
it would seem if a coil were to go out . it would take out 2 cylinders.
Discussion Starter #20
That is similar to the diagram in the shop manual and it does indicate that two cylinders will be lost with a single coil failure.
Am I back to square one figuring this out?
I did pick up a coil pack for a Neon and will be attempting the mod this weekend.
1 - 20 of 38 Posts
