1 - 3 of 3 Posts
hey guys, i have a 1983 gl1100 interstate,the issue i am ahveing is that when you turn right it shuts down,all the indicator lights go off and the bike stops running.i cant figure out why...??? i need help trying to get rideing.:sadguy:
:waving:
if you put the bike on the center stand and elevate the front tire off the ground does it still cut out when you turn the handale bars?
:waving:
if it does that look to see where the harness is and look for pinched wires or loose connections the ignition is on the right side of the triple tree and if its loose or pinched it could cause that "short"(one of my old kawasaki's had a similar issue)
1 - 3 of 3 Posts
