1 - 3 of 3 Posts
I'd like to spend a few minutes discussing an important step during engine install that I haven't seen posted anywhere else. This is for those of us who haven't pulled a goldwing motor before. I recently had to replace the stator in my 82 1100 and discovered something about the pulse generator on the rear of the motor. When you remove the cover, you will see a center rotor with two magnetic pickups on both sides. What you don't see is a spring loaded armatur plate sitting under the vacuum advance unit. While dissasembling I had made the mistake of removing the bolt from the center rotor and removing the rotor before I removed the vacuum advance housing. DON'T DO THIS! Instead, remove the cover, remove the vacuum advance housing THEN remove the center bolt and take the rotor with the spring loaded armature plate out AS A UNIT. During reassembly, you cannot install the armature plate onto the shaft and get the rotor on. The rotor has a small lip at the bottom that must sit under the arms in the plate. To install, spread the spring loaded arms and make sure the lip of the rotor goes underneath the arm tangs, then install on the shaft AS A UNIT, making sure that the armature plate lines up with the small pin in the shaft. NOW you can continue the reassembly.
This is my first goldwing so I don't know if this holds true for other models/years. I'm posting this to try to help someone else down the road not to make this same mistake, unfortunately, I don't have pics as when I discovered this I was in my driveway working in the 38 degree rain.
There is no need to remove the ignition assembly at all when removing the rear cover. You just have to be sure to line the pin up with the slot in the shaft when you put the cover back on.
1 - 3 of 3 Posts
