I had mentioned in an earlier post that Ihave a 83 GL1100, first Wing. The bike had sat for about five years when I got it. I did all the necessary things to get it running and it seemed to run quite well and loud with the totally rusted out exhaust.
I found and installed agood used exhaust and could hardly wait to hear it run muffled down, wish I hadn't--- clank--clunk--rattle! D-mn!
I've heard rod knock before and this doesn't seem to have that sound, but I'm not 100% sure.I did what I know to check the problem, (one at a time) run with plug wire off, plug out, rotate to tdc back off push piston with screw driver in plug hole to feel for movement-none.
It seems to be coming from the aft or near rear of the motor. It is as though something is loose- rotating and clanks-clunks when engine rotation catches up with it.
It only does this at idle. Bring it off idle even just a little and the noise goes away.
It reminds me of the noise you can hear in some V-twins with the uneven idle rotation, like my Vulcan does, but it is normal in that thing.
I know reading about a noise problem isn't as good as a trained ear, but any input would be appreciated.
I hope it is just a loose whatsamacallit on the doodad that is next to the thingamabob that turns the gizmo on the hoodinkthat has the whole thing catywompis and outakilter.
Thanks,
maxt
Thanks,
maxt
