Carb sync probably the entire problem... search for primary chain rattle..
Carb sync probably the entire problem... search for primary chain rattle......because the carbs need ballanced .
does anyone elses bike make this lower end rattle ....)
Welcome to this Great Site!Nash great buy.
The knoking is not realy a mechanical issue in the engine. It is gemeraly caused by cylinders out of sync and one piston is driving another sortof. This can be ignition sybc or carb sync. I have had my gl1000 for 3 months In that time it has rattled lots and little After I set the points and timming it was quite a bit quiter. It had issues some times and would get realy bad. I finaly pulled the carbs cleaned them and repaierd a broken plenum o ring it is smooth take off now no knocking. The other thing is these are wet clutchs and you have to slip them as you give it gas. If you dump them like you would a dry clutch they will knock>
Wilf
