This may seem long-winded, but I feel it would be better to lead up to why I'm using this.
I won't deny, this bike needs a lot of work, probably more than it's actually worth, but my stubbornness will not let me call it quits. Let me get to my main problem that is keeping my from going any further.
I am having starting issues with going through multiple solenoids to find a solution. First was the original solenoid which had the bone blade fuse. That wasn't doing the job, and I've basically summed it up from what I've read on the net and these forums that it's pretty much crap. So I scrapped that solenoid and went to a universal solenoid that I've read was a good upgrade.
Before reading about the F492 Solenoid, this is what I was using. The image is the second one. The first one crapped out about year back. First time using the first one of this same type, it worked for a bit. I was able to get the bike to turn, but it would only run for 30seconds at most without playing with the throttle. Pulled the carbs, cleaned out everything, jets and all, put it all back together. after that, started it up, would run for a minute or so without playing with the throttle. Then adjusted all the outside carb screws by ear, then fired her up again. In Neutral, no Throttle play, she ran beautifully for 30 minutes untouched until I cut her off.
Btw, I did all those starts by jumping the battery because it wouldn't hold a charge. After it ran for 30min and I cut it, I pulled the battery and let it slow charge overnight. Put it back in the bike and the Solenoid would only click. Pulled the Starter thinking that would be the issue. Reason being, even though I got the bike started, when starting, it did seem to have a slow drag before kicking. So after pulling it out, tried a lone starter jump to see if the gear would turn. It looked and sounded as if it was struggling before it stopped. Pulled it apart, cleaned it up, repacked it, and still the same effect.
At this point, I was hard on cash and couldn't do anything else for a good while sadly. A year has passed, I knew what needs to be done. Needed to clean those Carbs again which I did on Sunday. And after I can atleast hear it attempt to turn, I will need to drain the old gas and do an oil change, simply because she has been sitting for a good while. anyways...
I saw on eBay, an Auctioned Starter that I won for $36. Before I installed it, after arriving 3 days later, I bought a new solenoid as shown in the image above as well as a new battery. Installed the new(used lol) starter and tried to start it, only getting clicks. So then i installed the new solenoid, turn the key and the starter started turning, a lot better than the original starter too. No weak drag like the last. She didn't kick, but at least she was trying, for a bit... pulled off the fake tank, the air filter, and grabbed a can of starting spray, sprayed a little into the Carbs, almost had it kick, then "click...click........click...." My hopes down the drain...
Been reading up on the web and the forums for solutions. Been seeing Tractor, ATV solenoids, but the most common one I've seen was the "Victory Lap" F492 ford Solenoid. this:
From what I've read unless misinterpreting it. Yellow/Red to "S", Battery to Left, Starter to Right, "I" not in use, and Green/Red to base of Solenoid like so:
Everything connected, and I get nothing, not even a click. What could I be doing wrong?
I'm trying the Ford route, because I've read that not only is it more affordable, but supposedly more reliable as well. I've also pulled my grounds and cleaned the contacts and surface with a small copper brush for clean contact.
