1 - 2 of 2 Posts
I am involved in many projects on my 1980 GL1100, and lubing the final drive properly is high on my list. When I got the bike last summer, I put new tires on the bike, so greased the final drive/wheel splines with my trusty green "sticky grease" that I have used successfully for years. Well, I have grown to trust the forum, and everyone is clear on using the 60% moly grease, so off to Honda I go.
According to Exavids post (link below) I just have to lube the (2) splined ends of the driveshaft and the wheel hub spines
ShouldI remove the c-clip under the boot near the trans output and pull the drive shaft out to do this properly?
I know I also have to clean and lube the final drive/wheel hub splines as well.Are these the only spots I need the 60%moly?
Thax for all the great advice on the old bike from the long-time and new wingers !!!
http://www.goldwingfacts.com/forums/view_topic.php?id=40544&forum_id=1&highlight=final+drive+lubrication+
Yes you do have to remove the clip on the shaft and slide it back to get any grease on it. Those areas are the only ones I know of that call for the moly specifically but it's also good to use on the brake caliper slides and on the metal contact areas of the brake pads.
1 - 2 of 2 Posts
