1 - 3 of 3 Posts
I'm rebuilding some 1100 carbs, got a question I cannot find an answer or diagram to:
The tiny wire clip that holds the float valve onto the float itself, does it matter which way
the clip's opening faces when assembled? It can either face the float hinge pin, or away from it...
does it matter, will it affect float valve operation? (pix attached)
324034
324035
Doesn't matter.
That's what I thought... even though the clip actually doesn't "center" on the valve when it's on there, the "hangar" part of the clip sits off to one side slightly, maybe .5mm
(y)
1 - 3 of 3 Posts
