Of course I'd take them back. And why should you have to pay anything if it's leaking. At least take it back and point out the problem. You spent 1200 already. They should fix it. I trust you didn't over air them. Have them take the seals out and check the tubes with them present and see if there are any nicks, burrs, etc that could cause a leak, look at the seals to see if they are OK. If any of this exists they should realize they didn't finish the job properly. My oil is not measured by ounce's, it is measured from the top of the tubeto the oil surface with the tubes collapsed and the springs out for progressive springs, but then I have a 1500 and you are talking about a 1100. Just pointing out that perhaps they measured and did not use the measuring method. Did you have the bushings replaced as well or just the seals, if the bushings are bad, they can in turn make your seals leak even if the seals are new and this would not be their fault.
In retrospect, there is enough information and helpon this forum, you could do this all yourself.
