the valve seal is probley worn. when you rotated it around to turn on you applyed enouph side pressure on the seal to make it leak. tank hot and pressurized frome the sun. rebuild or replace valve .
Well, if you see above, the petcock is rebuilt. It was a kit from Randakk last fall right before winter. I doubt it s 3000 miles on it. I have since poked, pried, grabbed, and cant duplicate it. Randakks seal is viton. If its already wore out, im going to have to rebuild it alot. Thats why i was shocked when it happened. The petcock seal is new, hises, filter, everything.....that viton seal should be the strongest part in my fuel system...gonna have to keep an eye on it.....maybe pull it apart and check iy but wow!!!.....hmm...the valve seal is probley worn. when you rotated it around to turn on you applyed enouph side pressure on the seal to make it leak. tank hot and pressurized frome the sun. rebuild or replace valve .
Nah, actually since I live in Indiana, I wanna get some use of all this corn around me so I use E85....afterall, the government says its great fuel!!!:raspberry:Are you using motorcycle gas and not car gas? :ROFL:
OK but how much. My petcock o-rings got blown out but stopped leaking after I removed the cap. I have to think its supposed to vent off presure at some point. THANKS!!!FYI the cap is supposed to hold pressure.
A fuel tank never vents air, they are fuel vapors and bad for the enviroment not to mention stinking up your garage and in the extreme could reach concentrations which would be an explosion hazard. Would you like to be in an underground garage with 100 cars holding 2000 gallons of fuel all venting their vapors to atmosphere.:ROFL: These aren't a lawn mower holding 15 ozs. with the familiar hole in the center of the cap from Leave it to Beaver.I disagree with some of the above. Your fuel cap should vent air out and in with a small amount of pressure each way.
Since you're the smartest guy on the forum, likely the internet, possibly the world and you're never wrong, why not apply for the job? :?This is ridiculous!!!! Isn't there any moderation on this forum to stop the level of wrong information that goes on here?
Scott
beeeeee-waaaaaaaaaaaaaa!are you using motorcycle gas and not car gas? :rofl:
If that were the case, they'd have to delete half of your posts. Maybe even a couple of mine (mind you, just a couple)Isn't there any moderation on this forum to stop the level of wrong information that goes on here?Scott
I thought this thread was about a thirty one year old Goldwing.:?FYI. No tank is designed to vent to the atmosphere any more.
They are designed with any number of evaporative devises to TRY to collect and re-burn fuel vapors.
