1 - 2 of 2 Posts
The Honda Manual says, 15 ft lbs torque for "fuel pump bolts." Just wanting to make sure. Are these for the two 10mm bolts that go into the head?
Finally had time to do a little work on the Bike yesterday. Located, I think, the little coolant leak . . . the upper hose clamp needed tightening. I got my 35 watt driving lights hooked up. Replaced the fuel pump, which was leaking slightly (made sure I didn't over tighten until I confirm proper torque . . . it's not leaking). Tightened the shift lever (going to need a new seal it looks like). And, installed driver floor boards for my wife!
It always feels good to get a few bike things done.
Next on the list is hitch install and wiring for the trailer I got: a Harbor Freight with a swivel tongue, and a Sears carrier to go on top.
Chuck
Guru
sounds right. it will feel in between snug & tight for a bolt that size. Clean lightly oiled threads for an accurate reading.
1 - 2 of 2 Posts
