Can anyone make any sense of this???
I am now on third different engine block and second set of heads. Can anyone explain to me why i keep popping head gaskets? First motor was my own fault, let it run to long trying to get the plug for fan temp sensor to work overheated it and blew head gasket. Tore everything down checked for warpage and was less then .002 or somewhere close. That gasket lasted till timing belt jumped teeth so changed heads due to broke valves . So put everything back together that gasket lasted for 2 years then had to tear it all apart again gasket went and oil was more antifreeze then oil. So bought another bike with a freshly rebuilt engine. drove it for a month and head gasket went in it???? this one is just leaking into just one cylinder and being burnt no antifreeze in oil??? Can anyone explain why i am having such a problem with head gaskets?????
I can tell you from experience there is no substitute for OEM Honda head gaskets, Been there done that with several. Now 32,000 on honda gaskets and still going.
please don't take this the wrong way, i'm not trying to offend. you shouldn't be going through that many oem gaskets. perhaps you may need to re-evaluate either your mechanic or your riding habits? just trying to help.
Torquing the head bolts properly with a dab of Molly-60 under the flange?
Discussion Starter · #9 ·
Trashtruck i am the mechanic so you could be right, i have no formal school training just what i have learned myself and my driving habits could also be at fault? It does occasionally get up around red line.
Ansimp i check all fluids everytime it leaves the garage.
Oldschool did torque to specs according to manual but did not have moly-60 under flange on the ones i built can not say about the last one as i didnt do that one. It was done buy a trained mechanic so i was told by PO.
Riding i have the head off now cleaning it up going to check everything sometime this week and put it back together. Hopefully you are right and i wont have to do this again.
Moly 60 on the threads also, per the shop manual.
