gl1100 with perforated exhaust headers, was going to weld up the holes but welding rust is a bit of a pain, or put stainless pipe inside/flexible exhaust pipe outside
she's not really noisy but it's been an advise on the last 3 mot's and the fumes coming up from the headers is a pain
will either the 1000 or the 1200 (which have separate headers) fit the 1100
anyone know ?
i do belive the 1000 headers will fit the 1100. they are separated by a joint to the muffler. not sure on the 1200.
1200s will not exactly fit. I have them on my 1100 but I had to bolt them to an engine and heat and bend them out a little to make them work.
dave, do the 1200's fit at the head but the pipes are too close to the frame?
my plan is headers and harley silencers connected with flexible exhaust tubing
If all you want are the headers then any 1100 should fit. If you're after the complete system, the 83 crossover tube is in a slightly different place so you have to replace both sides so that they match up - or fabricate - or cap off. There's been some discussion about whether a crossover tube is necessary. I always add one if I change a car from single to dual exhaust. Never did get a definitive answer from the m/c jury.
And instead of flexible have a shop tack on extra lengths of stainless to the headers. Would look much better.
100's headers will fit..75-77 go straight back..78-79 turn up a bit..makes a difference for the mufflers hook up
The 1200 headers will bolt onto the engine. The angle for the pipe coming off is a bit different. I cut it at an angle and welded an adaptor piece in place to fit my Harly pipes..
They bolt to the head but they butt up against the engine block so they are at an angle to the port and won't seal. They are a bear to heat and bend but I can attest it can be done.
Strange. I didn't have that problem.
I ran my Interstate with Harley pipes alongside my Aspy with stock pipes and they sounded very similar. No sealing issues and I didn't have to bend them.
They may seal off with new gaskets but I didn't like the pipes being against the block like they were. I do remember now having to cut the end off and weld it back at a different angle especially on the right so it would clear the brake linkage.
