· Registered
Can someone please tell me what are some of the problems with my 1982 goldwing 1100 interstate. I am not getting any power to my ignition switch,I have replaced starter,solenoid and battery and fuse by the solenoid.
· Administrator
Does it still have the 4 pin connector on top of the solenoid? If it is aftermarket it may not be wired the same and have the power wires on the wrong terminals.
2007 1800 Crucible Orange
Welcome and Hello . Be sure to double check the fuse at the starter solenoid ( the main fuse ) From the solenoid a smaller RED wire should be hot . At the ignition switch you should also find a smaller red wire ( the other end of the one at the solenoid)
Yes, some aftermarket solenoids are wired different at the connection block. There is a lot of info about that on the internet. You really need to sort that out before going further.
Scott
