1 - 3 of 3 Posts
Recently I've been working on my 33k 82 interstate and found the right bag seal missing, that brought back memories when I owned mine in the early 80's.
Back then, the lids were pulling off the weatherstripping on occasion. The cure is to clean off the paint over spray/rough abs with fine steel wool/sandpaper from the inner lip, then some silicone spray on the "saddlebag/trunk seal" and you'll be amazed at the difference.
That must be on the lid you are using the steel wool & spraying, not the seal, correct?
1 - 3 of 3 Posts
