With start is perceived the knock in the gearbox, and then, after the curtailment of acceleration one additional knock and jerk.
I think that reason in the weak spring of damper on the drive shaft of Cardan joint.
It is possible to restore the correct work of this unit?
mine is doing what you describe when starting cold. I have presumed it is a timing issue and am about to go out and re-time and double check point gap. :)
Patrick, I think he's refering to the clonk, (often described as a bowling ball rolling in the trunk) that you get when accelerating hard. I believe it's caused by a spring and ramp type damper in the driveline which acts as a shock absorber.....Steve
steve worth,
Yes, very correct words!
There is the method to correct (to overhaul)?
to place under expansion washer?
to replace by the more elastic?
possibly the wear of the forks of clutch?
I think it is just something the bike does. I do not think you can fix it. Pehaps somebody else can tell us different
....Steve
At times there can be just too many different clunks on these GW's. LOL... So steve (or anyone) what about my clunk? Do ya think I am on track for mine? :)
When I took my 83 Aspencade down and let The retired Honda Mechanic listen to it, he told we there was a chain that went from the starter and over the Transmission. I always thought it went over the starter. I did not know that. He said it would clear up after a sync. He also sid bad Plug Gap would cause a knock if U had a cylinder missing, or running on 2.
Nightrider1
