try blanceing the carbs 1st
Hi,sounds good....anything the manual doesn't cover that I should watch out for or common problems when performing this?
Follow this forum link.looks like i'm gonna order the Carbtune Pro 4 port.....
The Above is very true. Also the Valve Settings. If you adjust the valves out of sequence, you still gonna to re-do them. Make sure the #1 Piston is Top Dead Center on the COPMPRESSION Stroke and it is aligned with the T1 Mark. If it isn't, rotate the generator 1 complete turn clockwise and it will be. Set valve clearances using a feeler guage.sadisticcycles wrote:Hi,sounds good....anything the manual doesn't cover that I should watch out for or common problems when performing this?
Synchronizing the carbs requires a specific sequence. Left bank, right bank, side to side.
where is the dang T1 mark???? I was doing it by watching the arms and wiggling the ex & in and if they both wigle it's TDC....right?Bike...and Dennis wrote:The Above is very true. Also the Valve Settings. If you adjust the valves out of sequence, you still gonna to re-do them. Make sure the #1 Piston is Top Dead Center on the COPMPRESSION Stroke and it is aligned with the T1 Mark. If it isn't, rotate the generator 1 complete turn clockwise and it will be. Set valve clearances using a feeler guage.sadisticcycles wrote:Hi,sounds good....anything the manual doesn't cover that I should watch out for or common problems when performing this?
Check for these Valve Clearances Below IN SEQUENCE!!!
Cyl#1 Intake Settings--- (Valve Clearance COLD --INTAKE 0.10mm or 0.004 in)
Cyl#1 Exaust Settings--- (Valve Clearance COLD -- EXAUST 0.13mm or 0.005 in)
Cyl#3 Exaust
Cyl#4 Intake
Next, Rotate the Generator 1 complete turn and stop on the index mark. Make sure the #2 Cylinder is at Top Dead Center on the COMPRESSION Stroke.
Check for these valve Clearance below: Note they are opposite of the top that were done first. Follow these instructions, and replace the covers annd you are good to go.
Cyl#2 Intake Same Valve Clearance Cold on all. Note Settings above
Cyl#2 Exaust
Cyl#3 Intake
Cyl#4 Exaust
Hope this helps!
Good Luck,
Nightrider1
