I was looking around in Princess Auto about a month ago and found some LED trailer lights that looked to be about the same size as the reflectors on the side of my '83 Aspencade.
So I decided to see what it looked like if I bolted it to the base the holds the factory reflector.
But that didn't look "factory" enough for me. So I cut the LED part out of the new light and made a hole to fit it into the stock base. The LED and circuit are embedded in epoxy so they are waterproof. Then I used JB Weld to attach the two pieces together and some black silicone to seal up the whole assembly.
The lens off the LED marker light fits perfectly on the edge of the stock reflector mount.
So the next part is not for the faint of heart. I took my Dremel tool and cut a hole for the back of the light to fit into. With that part cut out you cannot use the factory hole to secure the light, so I drilled 2 hole for the bolts that go through the lenses and 1 hole for the wiring to pass through.
Then I used black silicone to seal the lights from the back. Since they are LEDs they should never need to be replaced.
I ran the wiring for the saddlebags along with the factory wiring up under the seat and tapped into the taillight harness. The fairing lights are wired into the running light circuit at the front turn signals. With the wiring setup this way, the rear lights will light up when the ignition switch is set to "P". The front lights go out when the turn signals are turned on, which I'm not completely pleased with and I may change later.
So here are the final results. I used 4 amber lights because I like the way they look with the amber turn signals in my saddlebags. Red ones are also available if you wanted to go that route. The LEDs were on sale for $4.99 each and with all the other supplies I bought the total cost was around $35 and a bunch of my free time. Not bad considering they look 100% factory to the average person, the lenses are DOT approved and still work like a reflector.
Thanks, I kinda like doing mods that the average persons doesn't notice. Now I need to change some of the other lights on the bike with LEDs.
· Senior Memory
Awsome job. Very nice look. Thanks for sharing. I thought about converting some of mine but they are totally different design on mine so if I doo I might post a step by step. Might be a while til I get the other lil gremlins outta my bike first.
That looks great, creativity at its best.
Chuck
Thanks for the compliments guys. I just found a link to a site that sells these LED lights for those of you who don't have a Princess Auto store nearby.
Trailer Parts Superstore
They have the amber ones and the red ones.
Discussion Starter · #9 ·
That was my original intention, but when I bought the lights I realized the LEDs were encased in epoxy. Then I thought about, the previous owner cut a hole in the fairing for a radio, so I wasn't chopping up a mint fairing. The saddlebags are not perfect either so no big loss.
I have one of these, in red, from superbrightleds.com:
It says "not suitable for automotive applications" because it accepts only 12v (not 10-15v, like their automotive ones do), but that's nothing a 7812 regulator won't fix.
The thing is too large to mount in behind the reflector, so I'm thinking I will just desolder all the components themselves, drill 6 holes in the back of each reflector, and push one LED through each hole. Then tack solder them all together, cover all the electronics in some liquid electrical tape to make it waterproof, and mount it back on the bike as is. That's the plan I have right now, anyway. :)
