GL1100 lighting for speedo and tach instruments
814 Views 9 Replies 5 Participants Last post by  Ken1
Hi,
I just lost the lighting for the speedo and tach instruments. The fuse is good. I have all other lighting but no speedo and tach instruments lighting.
Anybody knows what gives?
Ken
someone will be along to help soon if not PM dave430
What about temp and fuel gauge lights?
Yes, those are out also. I have just checked and I don't have any clearance lights either. Not the brake light (which works) the clearance light on the taillight.
Check the # 3 tail main relay. Swap it with the # 5 air pump relay for a test.
Where are those relays located?
Sorry Ken1, My response was relating to a GL1500. I see you have a GL1100. The same theory may apply but I don't know where the relays are located.
No relays per se on the 1100, mostly fuses gone bad or a bad ground somewhere.
Ken1, update your profile to indicate where you live. There's plenty of us on here with 1100's and someone might live close enough to give a hand.
I am in Ken Caryl Valley. In Littleton, Colorado
