14.5 volts is good. If you are getting a drop from one yellow wire only with the engine warm, you might have an open circuit that only happens when the stator gets hot.
+1. I can't see how you're doing the test, but if the voltage were really that low, she probably wouldn't start the next time.It's really quite normal for the voltage to go down after it warms up, 12.5 t0 13v at idle is OK. There must be something wrong with your meter of method of testing, if your readings were correct it would not be charging much at all.
Trick question. Roscoe's doesn't have any!Hey Dave... If Mike keeps giving you crap just ask him how many 30amp dogbone fuse holders there are on a GL1200 Fuelie... :ROFL::ROFL:
No Abby Normal is the girl I should have married. I got AB Normal instead. :dumb:The correct verbiage should be "it's not AB normal".:ROFL:
Sounds to me like you're AB negative......I got AB Normal instead. :dumb:
